A Brief Introduction To The G sensor - wolfboxdashcamera
What Is G sensor
G sensor (Gravity sensor), also known as acceleration sensor (accelerometer), can sense the magnitude of acceleration. G sensor has been widely used in various industrial products, such as vehicle structures, G senser dash cams, etc. And even phones have them built in.
How the G sensor Works
If you want to further understand this issue ” What is G sensor”, you may need to know how the G sensor works.
Application Of G sensor In Autos
Application Of Dash Cam G sensor
There are also G sensors at work in some car gadgets, such as dashcam. Since WOLFBOX is a professional dashcam manufacturer, we will tell you more about dash cam G sensor in the next section.
How The G sensor Dash Cam Works
G sensors Meaning For Dash Cams
  1. When the vehicle is in normal driving condition, the dashcam will operate normally without being affected. However, with the G sensor, the dashcam can always monitor for unexpected behavior, such as violent braking, collision impact, or even movement when the vehicle is stationary (such as when someone shaking the vehicle). When dashcam detects such a change, it will trigger the so-called “emergency mode”.
  2. After entering “emergency mode”, the current video filewill be saved in the protected part of the TF card to preserve the video evidence and ensure that it will not be replacedin future recordings. This means that if your vehicle is involved in an accident, the G sensor will sense it and automatically direct the dashcam to save the current recorded video as an irreplaceable “emergency file”. This ensures that the video recorded before and after the crash is saved to the TF card intact, providing evidence to support the identification of accident liability.
Through such a complete process, dashcam with sensor can achieve both more accurate auto wakes up and longer standby time. With a simple accessory, G sensor, the dashcam’s native function has been revolutionized. The longer standby time can significantly reduce the frequency of charging the dashcam by the driver without affecting the timely recording of key video clips.
How Does Dash Cam With G sensor Help You
First, drivers will need the G sensor when they are involved in a more serious car accident. Not all car accidents are minor vehicle cuts, and in some of the more violent vehicle collisions, it happens that the driver temporarily falls into a coma. In this case, the dashcam with sensor can still automatically store the key video clips, even without the driver’s operation.
Secondly, G sensor makes it possible for dashcam to be on standby for a long time. Previously, to achieve 24-hour vehicle security monitoring, dashcam must be kept on. Because of the limited capacity of the battery, the dashcam usually could not standby long enough. But G sensor solves this problem perfectly. Thanks to the G sensor’s monitoring of vehicle movement, the dashcam can be selectively turned on by the G sensor’s alerts, thus ensuring that critical recordings are not missed while significantly extending the dashcam’s battery life. For example, when your car is hit or scratched while parking, G sensor will automatically wake up the dashcam to start recording and save the recorded video files separately, leaving you with the key evidence that can be provided when you call the police.
Take our Wolfbox product as an example, when the car is turned off, the dashcam screen will show “ACC is disconnected” and then go into standby mode, but the G sensor will keep working. When the car vibrates, the G sensor will automatically wake up the dashcam for about 10 seconds of recording, and then automatically shut down.
Tips About G sensor Dash Cam
G sensor Dash Cam Setting
The sensitivity of G sensor can usually be adjusted in the dashcam settings menu, and you can manually set the sensitivity to “high”, “medium” or “low” depending on the driving conditions. However, none of them can fit all scenarios, thus you need to set different G sensor dash cam setting according to different scenarios and their related usage needs.
Specifically, if you decide to drive off-road, you may want to set the sensitivity to “low” to avoid generating too many non-replaceable video files. Considering that mountainous terrain is usually undulating, if your car is off-road, then violent bumps may occur from time to time. Compared to normal road driving, most of the bumps are huge at this time. In this case, the high sensitivity of the G sensor will lead to multiple unnecessary triggers of the “emergency recording mode”, producing too many irreplaceable “emergency video files” in the TF card with no information value. Therefore, if you plan to drive to rally or off-road, remember to set the G sensor sensitivity to “high”.
Conversely, if you want to enhance security monitoring while parking, you can set the sensitivity to “High”. On the one hand, some vehicle vandalism by passers-by does not cause violent vehicle shaking, such as paint scraping, door banging or car theft. For dashcam to maximize its security surveillance function, you can set the sensitivity of G sensor to “high”, so that dashcam will record all suspicious vehicle shaking video as much as possible. On the other hand, not all parking spaces have security cameras nearby, and often, it is very difficult to get evidence of vandalism in places where there is no surveillance. Therefore, when you set the sensitivity of G sensor to “high”, dashcam can play the role of a 24-hour surveillance camera as much as possible. Based on the automatic wake-up technology we mentioned in the previous article, G sensor can help dashcam to achieve a long standby time, so it can achieve the role of 24-hour accident monitoring in a long-time span.
Many cottages of G sensor dash cams are only the rough integration of camera and TF card, and due to the absence of G sensor, the above related functions are all not guaranteed. Even if some of them are equipped with low-cost inferior G sensor, it may also face a series of potential problems, such as key video omission caused by the G sensor not advanced enough, and so on. In this regard, all dashcams produced by Wolfbox, such as G480S, G850, etc., are equipped with advanced G sensors, which can record key video clips as much as possible.
But we WOLFBOX can provide customer-consulting service and after-sales service with a high quality. After you purchase WOLFBOX‘s G sensor dash cams, if you have any questions about the use of the product or quality issues, you can always consult our dedicated customer service. Our customer service staff can provide detailed and patient answers to relevant questions. In addition, if dashcams break down during the warranty period, we can repair your dashcam for free. All these services are not available in the cottage dashcam products.
RELATED ARTICLES
