What does a jump starter do?
Snapinsta.app_431286142_451190543905813_421196345006768738_n_1024.jpg__PID:677c3e89-0171-4f2c-b8b2-d3b4e614ffa2
A jump starter is a portable device used to start a vehicle with a dead or discharged battery. It supplies the necessary power to the vehicle's battery to initiate the engine's ignition process. Unlike traditional jumper cables, which require a second vehicle, a jump starter is a self-contained unit, making it incredibly convenient for emergency situations.
How Powerful Should a Jump Starter Be?
The power of a jump starter is typically measured in amperes (amps). The required power depends on the type and size of the vehicle's engine. Generally, for small to mid-sized cars, a jump starter with 400-600 amps is sufficient. However, for larger vehicles like trucks or SUVs, a more powerful jump starter, such as those providing 1000 amps or more, is recommended to ensure reliable performance.
Will a Jump Starter Jump a Dead Battery?
Yes, a jump starter can jump-start a completely dead battery. It bypasses the vehicle's battery and delivers the necessary power directly to the starter motor. This allows the engine to turn over and start, even if the vehicle's battery is completely discharged. However, if the battery is severely damaged or has internal issues, it may need to be replaced.
Introducing the WOLFBOX MegaVolt24 Jump Starter
Unmatched Power for Every Journey
At the core of the WOLFBOX MegaVolt24 Jump Starter lies a formidable 24000mAh/88.8Wh battery, designed to deliver unmatched power and reliability. Whether it's a car, truck, boat, or even a larger vehicle, the MegaVolt24 can jump-start up to 40 times on a single charge.
No Guess, Clarity at a Glance
With the HD LED display, you can effortlessly monitor the status of your jump starter. This clear, easy-to-read screen keeps you informed about your emergency power source, ensuring you're always in control. In the heat of the moment, there's no time for guesswork.
Snapinsta.app_431392776_451190557239145_8195924356449000620_n_1024.jpg__PID:0171ff2c-78b2-43b4-a614-ffa26a1e4a45
Less Waiting, Fast Charging
The WOLFBOX MegaVolt24 Jump Starter is not just a powerful jump starter; it's also a high-capacity portable charger. Featuring a 65W Type-C in/out port and a QC3.0 USB-A port, it offers rapid charging for your electronic devices. Fully recharge the jump starter in just 1.3 hours with the included PD65W fast charger and 65W C to C cable.
A Real Beacon of Hope
The WOLFBOX jump starter is equipped with a 200-lumen LED flashlight. With SOS, strobe, and high-beam modes, this versatile flashlight provides essential lighting and signaling options in emergencies.
Snapinsta.app_431331497_451190523905815_238475413043392611_n_1024.jpg__PID:890171ff-2c78-42d3-b4e6-14ffa26a1e4a
Snapinsta.app_431329490_451190513905816_2840491586277061868_n_1024 - 副本.jpg__PID:7c3e8901-71ff-4c78-b2d3-b4e614ffa26a
Built Tough for Every Condition
The WOLFBOX MegaVolt24 is designed to withstand the elements. With an IP64 protection rating, this jump starter is resilient in harsh environments. Internally, it features 10 essential safety protections, including spark-proof, low-temperature protection, and high-temperature protection, ensuring safe and reliable operation wherever you are.
WOLFBOX MegaVolt24 Jump Starter with Lifetime Warranty  WOLFBOX
MSRP $129.99
