The Pros and Cons of Using a Dash Cam: What You Need to Know
Dash cams have become increasingly popular in recent years as a way to provide evidence in case of accidents or other incidents on the road. While they offer many benefits, such as recording your driving footage and providing a sense of security, it's important to note that there are also some downsides to using a dash cam. It's only fair to know both the pros and cons before deciding whether or not to use one. Some of the disadvantages of using a dash cam include the potential for it to drain your car battery, the amount of power it uses, and the question of whether it will record when your car is turned off.
In this article, we have discussed the advantages and disadvantages of using a dash cam, as well as answered some frequently asked questions about them. By understanding both the pros and cons of dash cams, you can make an informed decision on whether or not to use one in your vehicle.
What Do You Need to Use a Dash Cam?
To use a dash cam, you will need a few things. First, you will need a dash cam unit itself, which can range in price from affordable to quite expensive. You will also need a power source, which can come in the form of a car adapter or hardwiring kit. Finally, you will need an SD card to store your recordings. Without an SD card, a dash cam will not be able to record any footage. For some dual recording dash cam, you will also have a rear cam and other accessories.
![what you receive for using dash cam what you receive for using dash cam](https://cdn.shopify.com/s/files/1/0722/1077/6353/files/9_500x.jpg?v=1683705459)
The Disadvantages of Dash Cam
While dash cams are popular for their ability to provide evidence in case of accidents or other incidents on the road, they do have some disadvantages that should be considered before purchasing one. We will discuss some of the common concerns people have about using a dash cam.
Do Dashcams drain car battery?
While it is natural to be concerned about the power usage of a dash cam, the good news is that they don't actually require a lot of power. In fact, the amount of power a dash cam needs is minimal compared to the massive battery of your vehicle. So, you can rest easy knowing that your dash cam is unlikely to drain your car battery.
Do dashcams record when car is off?
Another common question about dash cams is whether they continue to record when the car is turned off. The answer is no, dash cams generally require power from the car's battery to operate, so they will not continue to record when the car is turned off. However, some dash cams have a parking mode that can be activated to record when the car is parked and the ignition is off. This mode usually requires hardwiring the dash cam to the car's battery or using a separate battery pack.
Does a dash cam record everything?
While dash cams can be useful for recording evidence in case of accidents or other incidents on the road, one downside is that they cannot record everything. It's important to keep in mind that most dash cams have a limited field of view that is focused on the road ahead, and they are not intended to capture conversations or activities inside the car. This means that there may be blind spots or gaps in the footage where important information may be missed. It's important to understand the limitations of your dash cam and use it in conjunction with safe driving practices to ensure the best possible outcomes.
Will dash cam work without SD card?
Finally, some people wonder if a dash cam will work without an SD card. The answer is no, a dash cam requires an SD card to store its recordings. Without an SD card, the dash cam will not be able to save any footage, which defeats the purpose of having one in the first place. The recording from a dash cam can be critical in case of an accident, as it can provide evidence to support your insurance claim or legal case.
It's important to choose an SD card with sufficient storage capacity and to format it correctly before using it with your dash cam to ensure that it functions properly and can store all of your important footage, which leads to another disadvantage of using a dash cam is that the storage capacity of an SD card is limited, and once it fills up, it will stop recording. This means that you need to regularly transfer the footage from your SD card to your computer or other storage device and format the SD card for new recordings. This can be a time-consuming task and can be easily forgotten, which may lead to missing important footage in case of an accident or incident. It's important to keep in mind that while dash cams offer many benefits, they also require regular maintenance and attention to ensure they function properly.
![SD card of dash cam SD card of dash cam](https://cdn.shopify.com/s/files/1/0722/1077/6353/files/32G-SD_-_-5_500x.jpg?v=1683705460)
The Advantages of Dash Cam
While there are some disadvantages to using a dash cam, there are also many benefits. Here are a few of the advantages of using a dash cam:
Provides evidence in case of accidents: One of the main benefits of using a dash cam is that it can provide valuable evidence in case of an accident. The footage can be used to prove who was at fault, which can be especially helpful in cases where there are no witnesses.
Enhances driving safety: Having a dash cam can make you a safer driver, as it can help you become more aware of your surroundings and adjust your driving accordingly.
Protects against insurance fraud: A dash cam can also protect you against insurance fraud, as it can capture footage of someone attempting to stage an accident or make false claims.
Provides peace of mind: Knowing that your dash cam is recording your driving can provide a sense of security and peace of mind.
In conclusion, while there are some disadvantages to using a dash cam, such as limited field of view, the need for an SD card, and limited storage, the benefits outweigh the drawbacks. Dash cams provide valuable evidence in case of accidents, enhance driving safety, protect against insurance fraud, and provide peace of mind. If you are considering getting a dash cam, it is important to do your research and choose a unit that fits your needs and budget.
